Date/Time: Thu, 10 Sep 2026 12:51:52 +0000
Historical Data
View Count: 885
| [2021-06-11 19:15:23] |
| User830573 - Posts: 6 |
I have logged into my account and filled out the agreements that were presented to me to see if that was the reason I stopped getting historical data. It did not fix the problem. I am using Rithmic as my data feed. Please advise.
| [2021-06-11 20:01:42] |
| John - SC Support - Posts: 47822 |
Sorry, but we do not give any technical support for Rithmic.
| [2021-06-13 15:13:02] |
Hello, but I pay the chart fee to Sierra and I cant get historic data when I rolled over contracts from June futures contract to the September contract!? |
| [2021-06-14 14:56:56] |
You should not be having any issue with the data from us. Is your chart setup as a Continuous Futures Contract Chart? Refer to the following: Continuous Futures Contract Charts For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-06-14 15:11:14] |
| User555930 - Posts: 4 |
hello, My continuous futures charts( ie zc# for corn) are not updating past june 3 2021. My specific contracts are updating fine. (zcz21 december 21 corn) I am running version 2273. How do i resolve this issue? thank you |
| [2021-06-14 17:13:47] |
User555930: When you say they are not updating past June 3 do you mean forward in time, or backward in time? Can you get us an image of what you are seeing? ----------------------- For future reference, for this kind of issue, you should post a new ticket for your particular issue. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-06-14 18:33:48] |
yes not updating prices for symbol zc# forward in time.
| [2021-06-14 18:38:32] |
http://www.sierrachart.com/image.php?Image=1623695889842.png
| [2021-06-14 19:24:10] |
User555930: It looks like you have a symbol of "ZC#". That is not an appropriate symbol. You would need to use "ZCN21-CME" (no quotes) for the July Corn contract. Make sure you update any other symbols that may be in the form of ??#. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-06-14 19:45:48] |
John, yes i know that zcn21 is the july corn contract. Until june 3 i was able to use zc# for a continuous corn contract...ie, march21, may21, july 21 all into one contract. ZC# was working fine until june 3rd |
| [2021-06-14 20:36:52] |
That is an old method for getting the Continuous Contract in Sierra Chart. We are surprised that it is even still working up to this point. You will need to use the new method of opening the symbol as we referenced above and then follow these instructions to setup a Continuous Contract: Continuous Futures Contract Charts: Using Continuous Futures Contract Charts For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
