Date/Time: Mon, 21 Apr 2025 23:36:10 +0000
How do you hide the "Symbol needs rollover" button?
View Count: 1140
[2021-06-11 12:30:13] |
Eric C - Posts: 5 |
Good morning, SC is prompting me to roll over my futures symbol to the fwd month, but I am not ready to do so. How do I hide the yellow prompt/button?
![]() Attachment Deleted. |
[2021-06-11 18:17:10] |
First, disable the following setting: General Settings Window: Detect Rollover Of Current Futures Contracts Symbols Based On Real Time Volume (Global Settings >> General Settings >> Charts >> Symbol) Then, if you want to add days to the official rollover date, you can do so by adjusting this setting: General Settings Window: Additional Days to Add to Rollover Date for Chart and Quote Board Rollovers (Global Settings >> General Settings >> Charts >> Charts) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-02-20 11:12:20] |
aknsyu71@gmail - Posts: 54 |
Also remember to restart sierra chart after you changed the above settings otherwise the yellow prompt will persist
