Date/Time: Sun, 27 Sep 2026 04:23:38 +0000
Rollover chart data error
View Count: 943
[2021-06-11 09:04:31]
User639401 - Posts: 5
Hi team,
I have performed ESM to ESU rollover. however, chart is unable to adjust backdate data by approx. 9 points.
the following is message log for your reference. Kindly note that I have deleted and redownloaded chart data and performed all the steps on Continuous Futures Contract Charts I am using rollover based on date and back adjusted.
Software version: 2238 64-bit | 2021-06-11 04:03:35.588
Primary Thread ID: 4792 | 2021-06-11 04:03:35.588
Usage end date: 2021-06-18 | 2021-06-11 04:03:35.588
Enabled for: Sierra Chart Historical Data Service. | 2021-06-11 04:03:35.588
Enabled for: Delayed Denali Exchange Data Feed. | 2021-06-11 04:03:35.588
Allow Support for Sierra Chart Data Feeds is enabled. | 2021-06-11 04:03:35.588
Current selected Data/Trading service: TransAct WS | 2021-06-11 04:03:35.588
Custom symbol settings values: disabled | 2021-06-11 04:03:35.588
Chart Update Interval: 40 | 2021-06-11 04:03:35.588
Intraday Data Storage Time Unit: 0 | 2021-06-11 04:03:35.588
Time Zone: -05:00:00 (CST-06CDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2021-06-11 04:03:35.588
2021-06-11 09:03:35 Local computer time in UTC | 2021-06-11 04:03:35.588
2021-06-11 04:03:35 Local computer time in SC Time Zone | 2021-06-11 04:03:35.588
2021-06-11 07:39:30 Server time in UTC | 2021-06-11 04:03:35.588
Local computer UTC time and Server UTC time difference: 0 seconds. | 2021-06-11 04:03:35.588
Program path: C:\SierraChart\SierraChartTransActMA\ | 2021-06-11 04:03:35.588
Data Files path: C:\SierraChart\SierraChartTransActMA\Data\ | 2021-06-11 04:03:35.588
OS Version Number: 10.0 | 2021-06-11 04:03:35.589
Locale Setting: C | 2021-06-11 04:03:35.589
DLLs: UserContributedStudies_64.dll | 2021-06-11 04:03:35.589
Allowed protected custom studies: | 2021-06-11 04:03:35.589
ESU1 [CB] 15 Min #4 | Reloading chart. | 2021-06-11 04:03:42.762
ESU1 [CB] 15 Min #4 | Date rule based rollover from ESM1 to next contract occurs at 2021-06-10. | 2021-06-11 04:03:42.762
ESU1 [CB] 15 Min #4 | Date rule based rollover from ESU1 to next contract occurs at 2021-09-09. | 2021-06-11 04:03:42.762
ESU1 [CB] 15 Min #4 | Skipping checking Intraday data file for symbol ESM1 since download was already done in last 24 hours. | 2021-06-11 04:03:42.780
ESU1 [CB] 15 Min #4 | Checking Daily data file for symbol ESM21 for the date range from 2021-03-11 to 2021-06-10. | 2021-06-11 04:03:42.782
ESU1 [CB] 15 Min #4 | Skipping Daily data download for symbol ESM21 since download was already done in last 24 hours. | 2021-06-11 04:03:42.783
ESU1 [CB] 15 Min #4 | Skipping checking Intraday data file for symbol ESU1 since download was already done in last 24 hours. | 2021-06-11 04:03:42.783
ESU1 [CB] 15 Min #4 | Checking Daily data file for symbol ESU21 for the date range from 2021-06-10 to 2021-06-11. | 2021-06-11 04:03:42.785
ESU1 [CB] 15 Min #4 | Skipping Daily data download for symbol ESU21 since download was already done in last 24 hours. | 2021-06-11 04:03:42.786
ESU1 [CB] 15 Min #4 | Symbols used for continuous contract chart: | 2021-06-11 04:03:42.788
ESM21 | 2021-06-11 04:03:42.788
ESU21 | 2021-06-11 04:03:42.788
ESU1 [CB] 15 Min #4 | Performing continuous futures contract back adjustment calculations. | 2021-06-11 04:03:42.788
ESU1 [CB] 15 Min #4 | Error while getting daily open price with date 2021-06-13 from file. C:\SierraChart\SierraChartTransActMA\Data\ESM21.dly. Error: No Data for read. End of file. | 2021-06-11 04:03:42.791
ESU1 [CB] 15 Min #4 | Error while getting daily open price with date 0 from file. C:\SierraChart\SierraChartTransActMA\Data\ESU21.dly. Error: No Data for read. End of file. | 2021-06-11 04:03:42.791
ESU1 [CB] 15 Min #4 | ESM1 price difference to ESU1 is 0. | 2021-06-11 04:03:42.791
ESU1 [CB] 15 Min #4 | Back adjust amount for symbol ESM1 is 0. | 2021-06-11 04:03:42.791
Continuous Contract File: C:\SierraChart\SierraChartTransActMA\Data\ESM1.scid. Start: 00:00:00.000. End: 2021-06-09 17:59:59.999 | 2021-06-11 04:03:42.797
Continuous Contract File: C:\SierraChart\SierraChartTransActMA\Data\ESU1.scid. Start: 2021-06-09 18:00:00.000. End: 00:00:00.000 | 2021-06-11 04:03:47.008
Chart #4 has tagged chart #1 for full recalculation. Chartbook: ES-KK.Cht | 2021-06-11 04:03:47.061
Chart #4 has tagged chart #3 for full recalculation. Chartbook: ES-KK.Cht | 2021-06-11 04:03:47.061
Chart #4 has tagged chart #5 for full recalculation. Chartbook: ES-KK.Cht | 2021-06-11 04:03:47.061
Chart #4 has tagged chart #6 for full recalculation. Chartbook: ES-KK.Cht | 2021-06-11 04:03:47.061
ESU1 [CB] 15 Min #1 | Performing a full recalculation because it has been tagged. Chartbook: ES-KK.Cht | 2021-06-11 04:03:47.073
ESU1 [CB] 3 Min #5 | Performing a full recalculation because it has been tagged. Chartbook: ES-KK.Cht | 2021-06-11 04:03:47.081
ESU1 [CB] 60 Min #3 | Performing a full recalculation because it has been tagged. Chartbook: ES-KK.Cht | 2021-06-11 04:03:47.099
ESU1 [CB] Renko 4t #6 | Performing a full recalculation because it has been tagged. Chartbook: ES-KK.Cht | 2021-06-11 04:03:47.105
[2021-06-11 17:36:49]
John - SC Support - Posts: 48028
For some reason you are missing the necessary daily files. On the chart for ES please select Edit >> Delete All Data and Download. Once that is completed you should have your problem resolved.
[2021-06-11 18:11:36]
John
I have performed this steps even before your suggestion and now as well. However, i am unable to resolve my issue.
kindly suggest next step.
thank you
