Date/Time: Sun, 20 Sep 2026 02:30:02 +0000
CUSTOM SYMBOlS (price changes per bar) clarification needed
View Count: 773
| [2021-06-09 22:29:30] |
| User220914 - Posts: 239 |
Hello to the greatest software engineers in land of trading! Question. If i am putting together say a custom symbol and to keep it simple as an example let say I build a symbol of (December soybeans - December corn) for 2021. if I choose (price changes per bar) can you explain to me how this would be calculated? would it be ONLY the price changes of the custom symbol or would it be the price changes of soybeans - price changes of corn thank you, just trying to understand how it would calculate say 100 price changes of a custom symbol of soybeans - corn |
| [2021-06-11 23:31:27] |
| Sierra_Chart Engineering - Posts: 24894 |
Yes it would be this: would it be ONLY the price changes of the custom symbol
Which would be much fewer than the component symbols. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
