Date/Time: Wed, 16 Sep 2026 07:55:08 +0000
Historical data service
View Count: 1162
| [2021-06-09 16:15:26] |
| Ale83 - Posts: 26 |
Good morning I am unable to view historical futures data. I have Sierra + Datafeed Denali real time advanced package and CQG for order routing. My broker is AMP and in data trade service setting he advised me to put CQG Web API: real time data works, but historical data doesn't work, I only see the future of the moment, not the past ones Can you help me? Thank you |
| [2021-06-09 16:51:52] |
| John - SC Support - Posts: 47903 |
Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Open a chart for the symbol you have an issue with. Tell us that symbol of the chart. Disconnect from the data feed with "File >> Disconnect". Connect to the data feed with "File >> Connect to Data Feed". After the connection and after about 10 seconds, provide a copy of the Message Log following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-06-09 19:18:17] |
| Ale83 - Posts: 26 |
The problem is that no message logs are created, the page remains blank. The symbol is F.US.EPM21. As if the historian did not exist |
| [2021-06-09 19:31:54] |
Do the following for us then: - Close your chartbooks by selecting File >> Close All Chartbooks - Select Window >> Message Log - Select Edit >> Clear Log to clear the Message Log - Close the Message Log window by selecting the X in the upper right corner - Select File >> Find Symbol - Enter F.US.EPM21 in the Selected Symbol area - Select the button for Open Intraday Chart - Select the button for Close - Select File >> Message Log - Select Send for Analysis at the top of the Message Log - Post here letting us know that the Message Log was sent. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-06-09 19:41:13] |
| Ale83 - Posts: 26 |
Software version: 2270 64-bit | 2021-06-09 14:36:50.941 Primary Thread ID: 44400 | 2021-06-09 14:36:50.941 Usage end date: 2021-07-08 | 2021-06-09 14:36:50.941 Enabled for: Advanced Features 2. | 2021-06-09 14:36:50.941 Enabled for: Sierra Chart Historical Data Service. | 2021-06-09 14:36:50.941 Enabled for: Denali Real-Time Exchange Data Feed. | 2021-06-09 14:36:50.941 Enabled for: Delayed Denali Exchange Data Feed. | 2021-06-09 14:36:50.941 Enabled for exchange2: CME | 2021-06-09 14:36:50.941 Allow Support for Sierra Chart Data Feeds is enabled. | 2021-06-09 14:36:50.941 Current selected Data/Trading service: CQG WebAPI | 2021-06-09 14:36:50.941 Custom symbol settings values: enabled | 2021-06-09 14:36:50.941 Chart Update Interval: 300 | 2021-06-09 14:36:50.941 Intraday Data Storage Time Unit: 0 | 2021-06-09 14:36:50.941 Time Zone: -05:00:00 (CST-06CDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2021-06-09 14:36:50.941 2021-06-09 19:36:50 Local computer time in UTC | 2021-06-09 14:36:50.941 2021-06-09 14:36:50 Local computer time in SC Time Zone | 2021-06-09 14:36:50.941 2021-06-07 22:08:22 Server time in UTC | 2021-06-09 14:36:50.941 Local computer UTC time and Server UTC time difference: 1 seconds. | 2021-06-09 14:36:50.941 Program path: C:\SierraChart\ | 2021-06-09 14:36:50.941 Data Files path: C:\SierraChart\Data\ | 2021-06-09 14:36:50.941 OS Version Number: 10.0 | 2021-06-09 14:36:50.942 Locale Setting: C | 2021-06-09 14:36:50.942 DLLs: UserContributedStudies_64.dll, zyp sierra free (2020)_2151_64.dll | 2021-06-09 14:36:50.942 Allowed protected custom studies: zyp_download_free | 2021-06-09 14:36:50.942 F.US.EPM21 1 Min #1 | Reloading chart. | 2021-06-09 14:38:08.821 HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (3) | Creating socket. Using TLS 1.2. | 2021-06-09 14:39:56.559 The message log has been sent to support. | 2021-06-09 14:39:56.559 * HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (3) | New receive buffer size: 32768 | 2021-06-09 14:39:56.559 HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (3) | Connecting to IP: 95.216.233.104. | 2021-06-09 14:39:56.559 Sending of the Message Log is completed. The response was saved to C:\SierraChart\Data\MessageLogAnalysis.htm | 2021-06-09 14:39:57.626 HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (3) | CloseSocket call. | 2021-06-09 14:39:57.889 HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (3) | Shutdown started. Waiting for graceful close. | 2021-06-09 14:39:57.889 HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (3) | Socket gracefully closed by remote side. | 2021-06-09 14:39:57.976 HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (3) | Closed. | 2021-06-09 14:39:57.977 |
| [2021-06-09 20:00:10] |
Can you please take a screenshot of what you are seeing by following these instructions: Support Board Posting Information: Attaching or Posting a Screenshot/Image (Optional) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-06-09 20:16:50] |
| Ale83 - Posts: 26 |
http://www.sierrachart.com/image.php?Image=1623269788908.png
| [2021-06-09 20:52:40] |
Are you not able to scroll back further in time back before about 12:57 in the chart?
| [2021-06-09 20:57:16] |
| Ale83 - Posts: 26 |
http://www.sierrachart.com/image.php?Image=1623272226196.png
| [2021-06-09 21:00:31] |
So I am very confused now. I thought you were not able to get any historical data in your chart. Where is the problem you are having?
| [2021-06-09 21:08:07] |
| Ale83 - Posts: 26 |
http://www.sierrachart.com/image.php?Image=1623272736176.png Nell'immagine ho caricato grafico a 1000 giorni di dati storici ma mi carica solo il future scadenza giugno, non carica i precedenti, anche se in advance setting ho segnato Continuos Future Contract. Io ho bisogno di visualizzare almeno gli ultimi 3 anni di storico dello struemento |
| [2021-06-09 21:14:17] |
From Google Translate: In the image I have loaded a 1000-day chart of historical data but I only load the future expiration June, it does not load the previous ones, even if in advance setting I have marked Continuos Future Contract.
I need to view at least the last 3 years of the instrument's history The Intraday charts you took the images of are not setup as Continuous Future Contract. We can tell as the notation at the end of the symbol is not there that indicates it is a Continuous Futures Contract. For instance, on the Daily chart you last posted, it has the [C] notation after the symbol in the upper left corner, indicating that it is a Continuous Date Based Rollover. For more information on the notation, refer to the following: Continuous Futures Contract Charts: Text Indicator Description Table For that 1-minute chart, you need to go to Chart >> Chart Settings >> Advanced Settings and set the Continuous Contract as you want it. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-06-09 21:35:34] |
| Ale83 - Posts: 26 |
http://www.sierrachart.com/image.php?Image=1623274492930.png Qui ho creato grafico day, con 5000 giorni di storico richiesti con contract continuos, come vedi ci sono molti salti negli anni,che lo rendono molto difficile da leggere,come mai? |
| [2021-06-09 21:38:00] |
From Google Translate: Here I created a day chart, with 5000 days of history required with contract continuos, as you can see there are many jumps over the years, which make it very difficult to read, why?
You need to use a "Back Adjusted" Continuous contract option in order to get the data to all line up between the changes in contracts. Refer to the following: Continuous Futures Contract Charts: Understanding Back Adjusted Price Data and Comparisons For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-06-09 21:46:42] |
| Ale83 - Posts: 26 |
http://www.sierrachart.com/image.php?Image=1623274492930.png ho impostato Back adjusted come da indicazioni, ma i salti ci sono comunque Mancano proprio alcuni contratti |
| [2021-06-09 21:47:49] |
| Ale83 - Posts: 26 |
http://www.sierrachart.com/image.php?Image=1623275149139.png Scusa questa รจ immagine corretta con back adjusted continuos contract |
| [2021-06-10 07:00:12] |
| Ale83 - Posts: 26 |
http://www.sierrachart.com/image.php?Image=1623275149139.png Potete aiutarmi in altro modo? Purtroppo anche facendo contract coninuos back adjusted la visualizzazione ha dei vuoti ,mancano proprio dei contratti |
| [2021-06-10 15:41:05] |
Change the Chart Data Type in Chart Settings to "Historical Chart". Refer to: Chart Settings: Chart Data Type (Chart >> Chart Settings >> Data Limiting >> Date Range and Limiting Method) Apply that setting and adjust the Days to Load to what you require. The historical data downloading will be much faster and less issues. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
