Date/Time: Tue, 26 Nov 2024 03:29:20 +0000
[User Discussion] - BaseGraphScaleRangeType
View Count: 1106
[2014-03-14 01:05:41] |
QnReally - Posts: 181 |
I have an ACSIL study that prints some text labels on multiple lines. When I change the scale of the main graph to a bigger number, the labels become squished because I use label offsets based on the TICK_SIZE (I tried Relative positioning also but it gets into some issues). Is there a way to determine how many pixels are in the chart from top of the scale to the bottom? In other words, I would like to know how many pixels are being used vertically for each sc.BaseGraphScaleIncrement value in the chart. I am using CONSTRANGE for the main graph and my study is set to Automatic scaling and it is drawn in the same region as the main graph. Thanks. Date Time Of Last Edit: 2014-03-26 18:55:39
[2014-03-31 12:24:15] |
By mistake I flagged my original question as hidden before. Now you should be able to see the message. Can you please let me know if this can be supported? Thanks.
