Date/Time: Mon, 25 Nov 2024 20:32:59 +0000
TD Ameritrade data problems
View Count: 1117
[2014-03-13 23:42:28]
lou_diamonds - Posts: 39
I'm having a problem pulling up the daily chart for the following tickers:
KATE - It only pulls the data from 02/26/2014 until current.
WAB - the stock split shows as a major gap, instead of displaying correctly.
VHI - the stock split shows as a major gap, instead of displaying correctly.
SIX - the stock split shows as a major gap, instead of displaying correctly.
RARE - It only pulls the data for the current day.
Can you tell me how to fix this?
[2014-03-14 01:00:17]
Refer to help topic 6:
http://www.sierrachart.com/index.php?l=doc/helpdetails6.html
For the charts that have a problem with a stock split, you need to re-download the data by selecting Edit >> Delete All Data and Download.
Date Time Of Last Edit: 2014-03-14 01:00:50
