Date/Time: Wed, 26 Feb 2025 23:28:24 +0000
Study SubGraph Reference study doesn't work with Current Bid/Ask line study
View Count: 444
[2021-06-08 11:04:43]
58LesPaul - Posts: 429
I have 6 Study SubGraph Refence studies on my chart for 3 Daily OHLC studies highs and lows. They work perfectly. I try to use the same study for Current Bid Ask Line study to extend the lines to the right edge and it does nothing. Is there a limit to these studies?
[2021-06-08 15:34:51]
John - SC Support - Posts: 38222
We are not seeing any issue with using the Study Subgraph Reference on the Current Bid and Ask Line study. The only issue we see is that if you leave the default Draw Style of "Line" then when a new bar starts, the line does not update on the previous bars. This is correct behavior, but it may not be what you want. Besides, if you are trying to get it to draw out to the right side anyway, then you should set the Draw Style to Line at Last Bar Left to Right.
But, that being said, you should just set that Draw Style for the Current Bid and Ask Lines subgraphs to get what you want. You do not need to use the Study Subgraph Reference.
For more information on Draw Styles, refer to the following:
Chart Studies: Subgraphs Tab >> Draw Style
