Date/Time: Fri, 11 Sep 2026 23:16:57 +0000
Transparent Fill Rectangle Bottom/Top issue with Spreadsheet Trading System/Alert
View Count: 1967
| [2021-06-08 05:37:24] |
| SabikiSensei - Posts: 76 |
Hello, support. I created a simple spreadsheet that gives an alert if a candle does +/-500 delta and closes where it opens or 1 tick away. No issues with the spreadsheet or anything. When I choose the draw style for the Buy Entry, I picked Transparent Fill Rectangle Bottom and for the Sell Entry I picked Transparent Fill Bottom. However, nothing shows up on the main graph when I choose this combination. If I choose Transparent Fill Bottom/Top for both, it'll work perfectly fine. Only when I choose fill top for one and fill bottom for the other, does the problem arise. I could probably make another spreadsheet and it'll solve the issue but I'd rather not unless there's a limitation with SC for this particular draw style combinations?
Date Time Of Last Edit: 2021-06-08 05:39:08
| [2021-06-08 14:50:58] |
| John - SC Support - Posts: 47854 |
The Fill Bottom/Top are expected to be used together in order to create a filled space. In other words, you should not be using those for what you are trying to do. You should really use a different Draw Style, like Arrow Up and/or Arrow Down. For more information refer to the following: Chart Studies: Notes about Top and Bottom Draw Style Pairs For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
