Date/Time: Wed, 26 Feb 2025 23:14:49 +0000
DOM new instance
View Count: 564
[2021-06-08 05:31:23]
User148596 - Posts: 217
Hi, I believe I read once that you recommend running the DOM on a separate instance. Is this correct and if so can you please share any relevant documentation? I have a lot of charts loaded in my chartbook so any advice you can give on the best way to approach this is most welcome. I'm not experiencing any issues that I am aware of.
[2021-06-08 14:47:13]
John - SC Support - Posts: 38222
The reference you are referring to is the following:
Overview of Trading: Sierra Chart Configuration for Most Low Response Time Trading
Also, refer to the following for other information related to resource distribution and performance:
High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often: 30.47 - Use Sub Instances to Distribute Processing Load
