Date/Time: Mon, 14 Sep 2026 08:43:19 +0000
Dear
View Count: 653
[2021-06-07 18:24:33]
User705217 - Posts: 1
I would like to be able to see number bars on couple charts for NYSE / NASDAQ traded symbol
What should I buy to be able
And how much roughly it cost
Thank you
Alex
[2021-06-07 18:40:06]
John - SC Support - Posts: 47854
In order to use the Numbers Bars, you will eventually need to be on Package 5. Right now, you are on a Trial, and that gives you the equivalent functionality of Package 5, so you are fine until your trial ends on June 22.
If you do not need real-time data for the equities, then you do not need to do anything further. The U.S. Equities are delayed, so they will update every 20 minutes or so (depending on your setting for File >> Data/Trade Service Settings >> Intraday Download Interval for Non-Real-time Symbols) and be within 15 minutes of the market.
If, however, you do want/need to have real-time data, then you would want to use the Sierra Chart Exchange Data Feed and activate the U.S. Equities exchange. You will find the Setup Instructions here:
https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#SetupInstructions
In terms of cost, here would be the breakdown:
- Package 5: $36.00 USD per month
- Sierra Chart Exchange Data Feed Fee: $25.00 USD per month
- Sierra Chart Exchange Data Feed U.S. Equities exchange: $10.40 USD per month
Total: $36.00 without real-time data
Total: $71.40 with real-time data
