Date/Time: Wed, 26 Feb 2025 21:46:18 +0000
Live Data
View Count: 424
[2021-06-07 16:28:38] |
Vasile Leuca - Posts: 3 |
I haven't used the platform since May 26, now I tried to log in to the platform and the data from May 26 until today is not updated, and it shows me the following message https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=51631 |
[2021-06-07 18:22:46] |
John - SC Support - Posts: 38218 |
Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Open a chart for the symbol you have an issue with. Tell us that symbol of the chart. Disconnect from the data feed with "File >> Disconnect". Connect to the data feed with "File >> Connect to Data Feed". After the connection and after about 10 seconds, provide a copy of the Message Log following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
