Date/Time: Sat, 19 Sep 2026 18:21:25 +0000
Region Data Line fixed positions / customize layout?
View Count: 1020
| [2021-06-07 16:06:50] |
| Mercrastius - Posts: 73 |
I've searched everywhere but I don't see a way to accomplish this: Some of the fields in the region data line / chart header change size slightly as their values change, causing the entire line of text to constantly shift back & forth horizontally. Moving the cursor around in chart trade mode also causes the issue as the price shown in the region data line adjusts. Is it possible to assign a fixed width to the individual fields to prevent this movement? On the same topic, it would be great to be able to customize the region data line similar to how control bars are customized. Things like adding blank spaces in between the data fields, or ideally being able to right-justify some or all of the fields would be excellent. Thanks in advance. |
| [2021-06-07 18:03:19] |
| John - SC Support - Posts: 47939 |
The only options available for customizing the Region Data Line are what are found here: Working With Charts: Region Data Line / Chart Header Therefore, the items you are asking for are not currently supported. We have set this thread as a Feature Request. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
