Date/Time: Mon, 10 Mar 2025 17:13:09 +0000
Accessing Numbers Bars
View Count: 772
[2021-06-04 19:12:20]
User339031 - Posts: 5
Is it possible to access Numbers Bars "Highlight Minimum Value" and "Highlight Maximum Value" from another study?
I know that you can get the point of control value from Numbers Bars Calculated Values SG42 but can't see how to get the minimum and maximum values.
[2021-06-04 20:42:37]
Sierra_Chart Engineering - Posts: 18732
No this is not supported.
[2021-06-05 03:05:26]
Have you got any plans for adding this ability?
[2022-04-06 00:20:22]
John - SC Support - Posts: 38541
We have added two new Subgraphs to the Numbers Bars study for the following:
- Price at Minimum Highlight
- Price at Maximum Highlight
The subgraphs contain the price data for the bar where the Minimum and Maximum highlight are located.
You will need to use another study to access the information in these subgraphs - such as the Study Subgraph Reference.
Just be aware that due to how the Numbers Bars information updates, you would not have any data for the bars that are loaded when you first open a chart, but the data will be present for new bars that are added. If you want to see data for prior bars, you would have to scroll back to that area of the chart and then force an update of the referencing study (open the study and select OK, for example). This will update the visible bars in the chart at that point. This is just due to how the Numbers Bars performs the calculations and the updating of the studies.
