Date/Time: Wed, 26 Feb 2025 21:19:48 +0000
Drawings Saving
View Count: 933
[2021-06-04 12:49:37] |
User886069 - Posts: 17 |
Could we save Drawings for the symbol in all chart windows when we switch, yes you have linking but it is not what i mean. I wanted to see what my drawings wherever i switch tickers....
Date Time Of Last Edit: 2021-06-04 12:50:12
[2021-06-04 17:02:19] |
Those are automatically saved when you save the Chartbook and you can see them through the Manage Chart Drawings Window: Chart Drawing Tools: Manage Chart Drawings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-06-04 18:38:58] |
i mean this
[2021-06-07 16:04:20] |
John - SC Support - Posts: 38218 |
Just ensure that the option for Show Chart Drawings for Different Symbols is enabled for the chart. Refer to the following: Chart Settings: Show Chart Drawings For Different Symbols (Chart >> Chart Settings >> Chart Drawings menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
