Date/Time: Wed, 26 Feb 2025 21:25:44 +0000
copy linesuntilfutureintersection on another chart
View Count: 461
[2021-06-03 20:55:01] |
User275592 - Posts: 97 |
Hi, i am using lineuntilfutureintersection on a 30 min chart to draw lines at specific values I d'like to copy those lines to a 10 sec chart (where i take my trades) maybe i could draw a classic line at the same value on the 30 min chart and use copy chart drawings but i don't know how to get the candle and value of each untilfuture line i did not find how to do this in acsil Thank you for your help Renau Date Time Of Last Edit: 2021-06-03 20:55:53
[2021-06-04 05:17:19] |
This is not supported in ACSIL.
