Date/Time: Wed, 26 Feb 2025 21:30:33 +0000
Data feed not working for trade evaluator
View Count: 571
[2021-06-03 19:09:08] |
Baynkr - Posts: 3 |
I'm not receiving live data for the Apteros Trading Evaluator. I've read and followed every single suggestion on this post: Intraday Chart or Chart Bars Not Updating | Blank Intraday Chart | "Currently no data to display" message for Intraday Chart Yet, the feed is not updating. I've already translated symbols, tried a quote board, and nothing. However, when I switch over to the data connection 'SC Data - All services' the data works fine. This leads me to believe there's an issue with the trading evaluator feed. Could you kindly assist? |
[2021-06-03 20:03:11] |
Sierra_Chart Engineering - Posts: 18571 |
You need to activate the required exchanges you require here: https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
