Date/Time: Sat, 01 Mar 2025 05:03:12 +0000
rithmic
View Count: 542
[2021-06-03 16:17:18] |
User124776 - Posts: 1 |
good day i wanted to trade an account via leeloo but rithmic doesn't work
[2021-06-03 16:33:59] |
Sierra_Chart Engineering - Posts: 18607 |
Check back with us in about three weeks regarding Rithmic. We are not able to support this now, but should be around that time. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-09-21 00:22:35] |
User257516 - Posts: 3 |
Hi, I cannot get data from rithmic either... I am using leeloo as well - followed all the steps but still can't access the data... |
[2021-09-21 00:49:11] |
John - SC Support - Posts: 38292 |
@User257516 - You need to be on Package 10 or higher, and since you are on a trial, you do not have access to one of these packages. Therefore, you would need to specifically pay for one of the packages 10+ in order to be able to connect to Rithmic.
