Date/Time: Wed, 26 Feb 2025 21:42:41 +0000
Data updates intermittent
View Count: 624
[2021-06-03 15:53:50] |
User190501 - Posts: 96 |
Hi Support, Using SC to get the data from TWS interactive brokers, the data is loading fine but it stops updating and then I need to disconnect and reconnect again to update. for example, if the time on the TWS chart is 11:50 , the bars are lagging on Sierra like on 11:20 and then I need to disconnect the Sierra connection and reconnect again to refresh the data. Is this expected ? |
[2021-06-03 16:21:07] |
Sierra_Chart Engineering - Posts: 18571 |
We do not provide any help for Interactive Brokers data. Refer to: Interactive Brokers Trading Service: Notice: Sierra Chart Does Not Provide Support for Interactive Brokers Symbols or Data Issues Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-06-03 16:34:22] |
even when I was registered with Denali, because there was the same issue -- I just switched to use IB only few days ago -- I can switch back to Denali but what is the reason of this issue -- even the volume data is not as shown in IB ! I am not using the snapshot data of IB even, it is a real time feed ! |
[2021-06-03 16:49:39] |
For the possible reasons for the issue, refer to: Intraday Chart or Chart Bars Not Updating | Blank Intraday Chart | "Currently no data to display" message for Intraday Chart And we do definitely recommend using the Denali Exchange Data Feed. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-06-03 17:38:29] |
I will switch to Denali but how to make sure that the data is not updating from IB ? I need only to received all data from Denali and just use the API to push the trades to IB.. I think the setup is mixing Denali and IB when we " Allow support for sierra data feeds " in common settings -- how to disable completely the data updates from IB ? |
[2021-06-07 14:37:11] |
John - SC Support - Posts: 38218 |
When you are setup properly with the Denali Exchange Data Feed, then that will take precedence and your data will only be from the Denali Exchange Data Feed. For how to verify that you are getting the data from a Sierra Chart data feed, refer to the bottom of this section: Real-Time Exchange Data Feeds Available From Sierra Chart: Integration with Trading Services For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
