Date/Time: Wed, 26 Feb 2025 21:52:15 +0000
there a way to make the bid ask horizontal lines width smaller? pic attached
View Count: 741
[2021-06-03 10:32:24] |
HeyUgly - Posts: 251 |
simple question any way to adjust the width of the 2 lines? they overlap my delta badly and hard to watch the delta fluctuate |
[2021-06-03 10:52:42] |
58LesPaul - Posts: 429 |
Open the Current Bid/Ask lines study and select the Subgraph tab. About halfway down in the middle is width/size. If that is a study you are using for the lines. If that is the "show bid/ask lines" under chart menu then I don't know of a way to change them.
Date Time Of Last Edit: 2021-06-03 10:57:07
[2021-06-03 10:55:36] |
very odd thing, i dont have that study on the chart, thats the issue. would it be in the number bars settings? |
[2021-06-03 10:58:29] |
If that is the "show bid/ask lines" under chart menu then I don't know of a way to change them. You might want to not use that and try the study. |
[2021-06-03 16:47:10] |
Sierra_Chart Engineering - Posts: 18571 |
Are those lines from Trade >> Draw DOM Graph on Chart?
