Date/Time: Wed, 26 Feb 2025 21:49:36 +0000
probleme data
View Count: 471
[2021-06-02 22:18:08] |
Nonospinal - Posts: 3 |
Hello, Since early June I have this error message when I open my charts and I have more access to the data, do you have an idea of the problem ? Arnaud thank you https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=51533 |
[2021-06-03 16:15:26] |
Sierra_Chart Engineering - Posts: 18571 |
You need to add sufficient credit to your account and then activate the CME exchange here: https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed There are many exchange options available, make sure you choose the correct one and ask us for help if needed. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
