Date/Time: Mon, 25 Nov 2024 20:41:41 +0000
Session times will stay saved
View Count: 938
[2014-03-13 15:10:56] |
User14266 - Posts: 225 |
I have a couple of ES charts that will not save the session time. I set the session time, and within 24 hours it's set back to 0:00 - 23:59.59. I have had to enter the session times, many times this week. This started when I started using CQG/SC feed. I did not have the problem previously, using CTS/SC feed. |
[2014-03-13 15:11:35] |
It doesn't seem to be a problem with my CL chart book. Just two charts in ES that I use VP and daily PP. |
[2014-03-13 15:52:01] |
Correction, subject should say "Session times will NOT stay saved". |
[2014-03-13 17:33:24] |
Refer to this section here about this: http://www.sierrachart.com/index.php?l=doc/doc_GlobalSymbolSettings.php#SettingIntradaySessionTimes Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
