Date/Time: Wed, 26 Feb 2025 19:29:46 +0000
service package
View Count: 472
[2021-06-02 00:42:11]
Galmik - Posts: 37
Hi i want to trade futures all contracts and size through my broker (IB)and have live data. Can u please tell me which service to choose. I am a beginner thank you a lot
[2021-06-02 14:08:20]
John - SC Support - Posts: 38214
Your package choice depends on your trading style and what you like to see in terms of indicators. You will find the difference between the Basic, Advanced, and Advanced with MBO Packages (Packages 3, 5, and 12) here:
Description of Service Packages and Pricing: Packages
Note that Packages 10 and 11 are the same as 3 and 5, but include the Denali Exchange Data Feed. If you want the MBO data, then you have to use the Denali Exchange Data Feed.
In order to connect to IB, you will follow these instructions:
Interactive Brokers Trading Service: Setup Instructions
The next question is then where do you want to get your real-time data. You can get it from IB or from us. We certainly recommend getting your data through us, as we have a direct connection to the CME Group and therefore it is low latency, high quality data feed.
If you want to get your data from us, then you will need to follow these Setup Instructions for the CME Group data:
If you want data from the EUREX, then you would follow these instructions:
https://www.sierrachart.com/index.php?page=doc/DenaliExchangeDataFeed.php#SetupInstructions_EUREX
