Date/Time: Wed, 26 Feb 2025 21:34:47 +0000
No MBO Data - Tried Everything!
View Count: 589
[2021-06-01 20:46:38] |
User429065 - Posts: 128 |
Was working until I switch account data from "CME with MDepth" to "CME with TOB". I may have done something in the "Global > Symbol Settings" but am not sure. See attached. CURRENT SETTINGS AS FOLLOWS: Updated to 2268 version SC Server Settings Window > yes & yes Global > Symbol Settings > Checked "use Custom Symbol Settings Values" > Reduced "Minimum MBO... " to both 4 and 11 (neither works) Chart Graphic Settings is set to Global Customize Chart DOM Columns > Combined Bid Ask Orders Column Disconnected Reconnected Date Time Of Last Edit: 2021-06-01 21:03:39
[2021-06-01 21:05:36] |
John - SC Support - Posts: 38218 |
In order to get the MBO, you need to have an exchange with Market Depth data. So it was the switch between the exchange options that caused you the problem.
[2021-06-03 16:03:47] |
Sierra_Chart Engineering - Posts: 18571 |
Refer to this section: Real-Time Exchange Data Feeds Available From Sierra Chart: Adding Support for CME Market Depth Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
