Date/Time: Wed, 26 Feb 2025 21:34:25 +0000
moving averages
View Count: 786
[2021-06-01 19:36:52] |
User627199 - Posts: 5 |
How do I set up a 20 day moving average and a 40 day moving average on the same chart?
[2021-06-01 20:41:14] |
John - SC Support - Posts: 38218 |
Put the 40 day moving average on first. Then add another copy of a moving average study, but set the Based On to the 40 day moving average. Refer to the following: Chart Studies: Settings and Inputs Tab >> Based On - Basing a Study on Another Study For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-06-03 11:51:04] |
How do I put the 40 day moving average on first?
[2021-06-03 16:50:12] |
Sierra_Chart Engineering - Posts: 18571 |
Provide an image of the chart or Trade DOM, by following these instructions: https://www.sierrachart.com/index.php?page=doc/PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-06-03 18:21:04] |
I need to be able to put the 40day moving average and 29 day moving average on all charts?
[2021-06-07 14:54:09] |
To have a 40 day moving average, you would first have a daily chart. Then add one of the Moving Average studies (such as Moving Average - Simple) and then set the Length to the number of days for which you want the Moving Average calculated. Refer to the information here: Moving Average - Simple For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
