Date/Time: Wed, 26 Feb 2025 19:53:46 +0000
[User Discussion] - Different scale values for multiple studies
View Count: 426
[2021-06-01 19:30:08]
lovelivelaught - Posts: 57
Hello
I have a chart with 4 studies in the same region. And I would like to change the scale of one of the studies so it could have same mid line? I use three TRIX studies with different periods in one region and I would like to add a MACD Hull study (that I found in custom study section). All 3 TRIXs that I have set as Automatic scaling and all of them have same mid line, which is 0 but when I add MACD Hull and set it to Automatic then TRIX studies is not visible as MACD Hull scale has different values that goes from 0 to lets say +- 20 but TRIX scale values goes from 0 to lets say +- 0.020. When I change MACD Hull to Independent scaling then its midline not always sync with all TRIX studies. Is there is any way that I can change scale values of MACD Hull so it can have same mid line with TRIX scale values.
I found a thread from 2021-03-19 under "scale multiple studies in same region & show zero values". I am not sure if that one would be the one that i should to refer to? If yes then I could not figure out where I have to go to change sc.Subgraph[0].DrawZeros = 1; and I think it should be a different number there anyway. I replayed on that thread and I got the answer I believe from the person who started a thread but the support board. He told me that I need to refer to Subgraph Study but I need more detailed explanation when it comes to spredsheets please.
Thank you in advance for your help.
