Date/Time: Mon, 25 Nov 2024 22:45:20 +0000
Symbol rollover
View Count: 1253
[2014-03-13 14:06:02] |
TradingMarketProfile - Posts: 120 |
Hello look at the YM chart, please and tell me why it's like that ? It was ok with H contrat and now on M, bad |
[2014-03-13 17:49:17] |
Please be more descriptive about the problem. When providing a chart image, it needs to be a very simple image containing no studies.
[2014-03-13 21:38:36] |
http://www.sierrachart.com/image.php?l=1394746490195.png June contrat (M) http://www.sierrachart.com/image.php?l=1394746536117.png March contrat (H) So as you can see it's ok with March contrat but after doing the rollover to June, there is data missing |
[2014-03-14 03:43:56] |
What you see is completely normal. We would assume you are familiar with Continuous Futures Contract charts? Here is the documentation for them: https://www.sierrachart.com/index.php?l=doc/doc_ContinuousFuturesContractCharts.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
