Date/Time: Wed, 26 Feb 2025 19:33:57 +0000
AMP Eurex problem
View Count: 601
[2021-06-01 13:33:26] |
User661695 - Posts: 5 |
Hi, I've an active account on AMP with Eurex data enabled, it worked for a long time fine, but today I can't get eurex data on sierra. Error window attached.
[2021-06-01 13:59:37] |
John - SC Support - Posts: 38214 |
At this time, it is necessary to get the EUREX data through our Denali Exchange Data Feed. Follow these instructions to get it setup: https://www.sierrachart.com/index.php?page=doc/DenaliExchangeDataFeed.php#SetupInstructions_EUREX For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-06-01 14:08:45] |
Ok, I'm interested in simulated trading only, so do I need to pay for AMP and Sierra + Denali, or Sierra + Denali is enough for that? Thanks for support.
[2021-06-01 15:22:50] |
You would just need Sierra Chart and the Denali Exchange Data Feed for the EUREX data. You do not need a trading account for the EUREX data.
[2021-06-01 17:22:42] |
Ok, I've set SC + Denali for Eurex and it works fine, but I've paid 23 $ for data feed and I've read that there is one month free trial. What can I do to get one free month?
[2021-06-01 18:22:54] |
The EUREX does not give a free trial. Refer to the information here: https://www.sierrachart.com/index.php?page=doc/DenaliExchangeDataFeed.php#ExchangeFeeTrials For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
