Date/Time: Wed, 26 Feb 2025 19:25:00 +0000
problem with stop limit order for
View Count: 465
[2021-06-01 12:57:20] |
User61576 - Posts: 445 |
my chart is for CLEN21 and trading for QMN21 when sending mkt order and limit it is working as expected but the stop limit (sent from the attached trade window) was rejected this is from the service log Trade Order Error - CQG order update. Status: REJECTED. Text: FIX field incorrect 'Illegal Price: '68530.0 contract 'QMN1' (ticks in 25, CAB of 0)' ExchangeRejectCode = 1011. Internal Order ID: 1853. Service Order ID: 1235819831. Symbol: F.US.NQMN21. Account: XXXXXX | 2021-06-01 08:39:44.978 * |
[2021-06-01 15:13:39] |
John - SC Support - Posts: 38213 |
What are the exact symbols that you are using in your chart?
[2021-06-01 16:42:11] |
File attached
[2021-06-01 17:38:34] |
Check your setting for Chart >> Chart Settings >> Advanced Settings 2 >> Real Time Price Multiplier. It should be 1.
[2021-06-01 18:14:16] |
it is set to 1 pls advice |
[2021-06-01 18:41:01] |
Sierra_Chart Engineering - Posts: 18570 |
The mini crude oil contract uses a different tick size. So you need to set the chart to that tick size. Refer to:
[2021-06-01 18:41:36] |
The mini crude oil contract uses a different tick size so you need to set the chart to that tick size: Chart Settings: Tick Size (Chart >> Chart Settings >> Symbol >> Symbol Settings menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
