Date/Time: Mon, 25 Nov 2024 20:50:27 +0000
sierra crashed...
View Count: 1071
[2014-03-13 13:13:33] |
steve_s - Posts: 11 |
Hi, running sierra version 1090 with win 7 pro and 12 gigs mem and sierra crashed today and this information popped up... Any idea why? I was about to copy/paste some information in a sierra spreadsheet and when I opened the "paste special" function it crashed. Thanks for any help. Steve. Files that help describe the problem: C:\Users\Steve\AppData\Local\Temp\WER39DC.tmp.WERInternalMetadata.xml C:\Users\Steve\AppData\Local\Temp\WER7C49.tmp.appcompat.txt C:\Users\Steve\AppData\Local\Temp\WER7D73.tmp.mdmp |
[2014-03-13 16:14:33] |
Most likely this has to do with spreadsheets. The spreadsheet functionality is being redeveloped. The new spreadsheets will not have a problem like this. Hopefully this does not consistently occur. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
