Date/Time: Wed, 26 Feb 2025 18:37:55 +0000
Trial of Volume Profiling
View Count: 561
[2021-06-01 07:03:31] |
User940293 - Posts: 2 |
I did join Sierra charts many years ago very briefly to run a system that I did not get on with. I would now like to trial the volume profiling, is this possible. Please advise. I have reset my password. Also can you advise me what package I would need to run the volume profiling, and the cost. Thanks Irene Cole
[2021-06-01 08:37:08] |
Sierra_Chart Engineering - Posts: 18569 |
Your account has been activated and the usage time extended if necessary. If Sierra Chart is running, it will automatically be activated within about three minutes. However, you may need to exit from the Sierra Chart charting and trading software by selecting "File >> Exit". And then open Sierra Chart through the icon on your desktop or through the desktop Start menu. After your Sierra Chart usage time ends you need to pay for additional usage time through "Help >> Add Usage Credit". Here is the documentation for the Volume by Price study: Volume By Price Study You just will require Sierra Chart Service Package 3: For Sierra Chart pricing, refer to this page: Description of Service Packages and Pricing Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-06-01 08:38:06
