Date/Time: Wed, 26 Feb 2025 18:35:39 +0000
ES Futures
View Count: 453
[2021-06-01 06:46:43] |
User223734 - Posts: 103 |
I noted the ES Futures data is not moving currently?
[2021-06-01 07:44:45] |
Sierra_Chart Engineering - Posts: 18569 |
We do not see any problem. First refer to this help topic: Intraday Chart or Chart Bars Not Updating | Blank Intraday Chart | "Currently no data to display" message for Intraday Chart And if you still have an issue we need to see the Message Log: Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Reconnect to the data feed: File Menu: Procedure to Reconnect to the Data and Trade Servers After about 30 seconds, provide a copy of the Message Log following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
