Date/Time: Wed, 26 Feb 2025 18:37:27 +0000
Intraday data
View Count: 508
[2021-06-01 05:28:34]
User824913 - Posts: 15
Hi, despite having followed the guide Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Instructions to Download/View More Historical Intraday Data
I can't see intraday data older than 2021-03-03.
In Chart Settings I set Use number of days in chart to 900
In Chart I set Continuous Contract --> Volume based rollover
I set Global Settings >> Data Trade Service >> Maximun Historical Intraday Days to download to 1000
I can't change Chart --> Date range in file (the system reset the value to the 2021-03-03
Itryed to start with a new chartbook without success
I use cqg as a datafeed
thank you
[2021-06-01 05:40:23]
We are no longer as of December 28, 2020 providing the Sierra Chart provided historical data service for CQG or Interactive Brokers users. For more information, refer to this Support Board thread:
Jan 1, 2021 Changes to Historical Data: Interactive Brokers, CQG
Also refer to this post for steps that you need to do now:
Jan 1, 2021 Changes to Historical Data: Interactive Brokers, CQG | Post: 245144
The solution to this problem is to use the Denali Exchange Data Feed for CME and EUREX data. Step-by-step instructions are here:
Let us know if you need help with the set up and we will help you through all of the steps.
In the case of CQG you will then need to contact your broker and cancel CME and EUREX exchange fees through your CQG account so you do not pay exchange fees twice. You definitively do not have to pay any market data exchange fees through your brokerage account to CQG. This is not required.
For other exchanges (ICE, HKFE) you need to use the Sierra Chart Exchange Data Feed:
As an alternative to CQG, we recommend using the Sierra Chart Order Routing Service:
Sierra Chart / Trading Technologies Futures Order Routing Service
In regards to using CQG provided historical data, we definitely do not recommend using that. It has an additional cost of 25 USD per month. The data delivery is slow and inefficient and causes Sierra Chart to freeze during the processing of it. Only 5 days of tick data is supported from CQG. And only current futures contracts are provided.
Whereas with Sierra Chart provided data feeds, you will have access to 10+ years of reliable high-speed delivered tick by tick data. Once again we do not advise using CQG historical data and it will not work well with Sierra Chart. And we also provide no technical help or support for any CQG provided historical data or real-time data.
