Date/Time: Fri, 25 Sep 2026 07:06:45 +0000
Data Service
View Count: 730
[2021-05-31 16:36:07]
User415776 - Posts: 7
What service pack and data feed do I need for OCO and Bracket orders in real time for CME Markets>
[2021-05-31 17:00:18]
John - SC Support - Posts: 48003
The Service Package and Data Feed have no impact on the ability to use OCO and Bracket orders. Those items are dependent on the trading service that you use, which is determined by your broker. For example, Sierra Chart does not support server-side Bracket orders for CQG.
We recommend using the Sierra Chart Order Routing service, which does support server side OCO and Bracket orders. In addition, you would then use the Denali Exchange Data Feed from us. For more information, refer to the following link:
Sierra Chart / Trading Technologies Futures Order Routing Service
Note that there is a partial list of brokers that support this service at Step #2 of the Setup Instructions on that page.
In terms of Service Packages, that just depends on your trading style and what you need in terms of studies. Refer to the differences in the packages here:
Description of Service Packages and Pricing: Packages
