Date/Time: Wed, 26 Feb 2025 18:51:43 +0000
Adding footprint values to bar chart
View Count: 483
[2021-05-31 13:18:22]
User525965 - Posts: 153
Hi! Is there a way to take the number bar (footprint) values at the edges and have them show on my trading chart (which is a bar chart)?
Or, if that is not possible, is there a way to highlight on my trading chart when there is excess or lack thereof on the pivots?
I attached a couple screenshots so you see what I mean. Thanks!
image2021-05-31_09-13-33.png / V - Attached On 2021-05-31 13:18:09 UTC - Size: 14.75 KB - 176 views
image2021-05-31_09-10-53.png / V - Attached On 2021-05-31 13:18:14 UTC - Size: 10.68 KB - 155 views
[2021-05-31 15:26:51]
John - SC Support - Posts: 38212
There is not a way to do what you are wanting using Built-In studies within Sierra Chart, as the Numbers Bars data is not directly available. You would need to use the ACSIL interface to produce a custom study to do what you want. Refer to the following:
Advanced Custom Study Interface and Language (ACSIL): Introduction
