Date/Time: Wed, 26 Feb 2025 17:40:36 +0000
Repeated Errors to Log: DTC Client socket (2) | Connect event error. Windows error code 10
View Count: 524
[2021-05-30 14:24:35]
User656492 - Posts: 146
Hi SC-
I'm attempting to get Instance 2 up and running cleanly.
I've been wrestling with this for several days now.
I thought everything was working properly, but while chasing down an unrelated issue, I looked in Message Log and found errors being reported. In an attempt to clean up the installation, I deleted Instance_2 to start fresh.
I then:
Created File-New Instance
Checked the Symbol List to see that it was already populated.
Loaded a chartbook into Instance_2 (nothing loaded yet into Primary Instance.
It took a few minutes to download all the data (maybe 20 instruments, 5gb of data over a 310Mbps connection).
The data all downloaded with many references to this:
CQG WebAPI (Market Orders Data) | Data feed disconnected. Will reconnect in 2 seconds. | 2021-05-30 07:08:43.737
Warning: More than one call into OnBufferedSocketReceivedData at same time | 2021-05-30 07:08:43.830
Warning: More than one call into OnBufferedSocketReceivedData at same time | 2021-05-30 07:08:43.917
Warning: More than one call into OnBufferedSocketReceivedData at same time | 2021-05-30 07:08:44.202
Warning: More than one call into OnBufferedSocketReceivedData at same time | 2021-05-30 07:08:44.324
Warning: More than one call into OnBufferedSocketReceivedData at same time | 2021-05-30 07:08:44.614
Warning: More than one call into OnBufferedSocketReceivedData at same time | 2021-05-30 07:08:45.362
CQG WebAPI (Market Orders Data) | Connecting to the server 127.0.0.1. Port 80 | 2021-05-30 07:08:45.750
DTC Client socket (3) | Creating socket. | 2021-05-30 07:08:45.750
DTC Client socket (3) | New receive buffer size: 5242880 | 2021-05-30 07:08:45.750
DTC Client socket (3) | Connecting to IP: 127.0.0.1. | 2021-05-30 07:08:45.750
Warning: More than one call into OnBufferedSocketReceivedData at same time | 2021-05-30 07:08:45.823
Warning: More than one call into OnBufferedSocketReceivedData at same time | 2021-05-30 07:08:45.942
Warning: More than one call into OnBufferedSocketReceivedData at same time | 2021-05-30 07:08:46.298
Warning: More than one call into OnBufferedSocketReceivedData at same time | 2021-05-30 07:08:47.069
Warning: More than one call into OnBufferedSocketReceivedData at same time | 2021-05-30 07:08:47.274
Warning: More than one call into OnBufferedSocketReceivedData at same time | 2021-05-30 07:08:47.452
DTC Client socket (3) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-05-30 07:08:47.806
After data downloaded and charts populated, the Message Log fills with this continuously:
CQG WebAPI (Market Orders Data) | Data feed disconnected. Will reconnect in 2 seconds. | 2021-05-30 07:12:22.000
CQG WebAPI (Market Orders Data) | Connecting to the server 127.0.0.1. Port 80 | 2021-05-30 07:12:24.002
DTC Client socket (2) | Creating socket. | 2021-05-30 07:12:24.002
DTC Client socket (2) | New receive buffer size: 5242880 | 2021-05-30 07:12:24.002
DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2021-05-30 07:12:24.002
DTC Client socket (2) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-05-30 07:12:26.050
DTC Client socket (2) | CloseSocket call. | 2021-05-30 07:12:26.051
DTC Client socket (2) | Closed. | 2021-05-30 07:12:26.051
DTC Client socket (0) | CloseSocket call. | 2021-05-30 07:12:26.051
CQG WebAPI (Market Orders Data) | Disconnected from the server. | 2021-05-30 07:12:26.051
CQG WebAPI (Market Orders Data) | Data feed disconnected. Will reconnect in 2 seconds. | 2021-05-30 07:12:26.051
CQG WebAPI (Market Orders Data) | Connecting to the server 127.0.0.1. Port 80 | 2021-05-30 07:12:28.047
DTC Client socket (2) | Creating socket. | 2021-05-30 07:12:28.047
DTC Client socket (2) | New receive buffer size: 5242880 | 2021-05-30 07:12:28.047
DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2021-05-30 07:12:28.047
DTC Client socket (2) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-05-30 07:12:30.097
DTC Client socket (2) | CloseSocket call. | 2021-05-30 07:12:30.097
DTC Client socket (0) | CloseSocket call. | 2021-05-30 07:12:30.097
CQG WebAPI (Market Orders Data) | Disconnected from the server. | 2021-05-30 07:12:30.097
CQG WebAPI (Market Orders Data) | Data feed disconnected. Will reconnect in 2 seconds. | 2021-05-30 07:12:30.097
DTC Client socket (2) | Closed. | 2021-05-30 07:12:30.097
Sierrachart APPEARS to be working, so I have no idea how long this has been going on. However, this is obviously symptomatic of an issue as the writing of these messages to the log does not stop.
PLEASE HELP.
THANK YOU!
[2021-05-30 20:23:05]
Sierra_Chart Engineering - Posts: 18569
We are checking on this.
[2021-05-31 02:04:26]
This log identified 2 different issues. We have resolved both of these. We are putting out a new release in about 30 minutes.
