Date/Time: Tue, 11 Mar 2025 02:08:01 +0000
POC x ticks from high/low of candle
View Count: 750
[2021-05-30 03:17:47]
Ben A - Posts: 123
I want to set up an alert for when the candle POC is x ticks from candle high/low. Is there a way of adding that to a formula, couldn't see POC in formula functions list
[2021-05-31 14:52:10]
John - SC Support - Posts: 38547
You would have to somehow get the POC into the chart as a Subgraph in order to use an alert on it. The study Volume Point of Control for Bars does exactly what you need. The Subgraph contains the price level of the POC for each bar. Refer to the information here:
Then refer to the following (and the section after it) for how to reference a Subgraph in an Alert Formula:
Study/Chart Alerts And Scanning: Referencing Study Subgraphs
[2021-06-01 12:19:54]
Ben A - Posts: 123
Groovy, thanks John!
[2022-04-27 13:07:47]
User482635 - Posts: 6
Hey Ben were you able to figure this out?
[2022-04-27 14:51:04]
Ackin - Posts: 1865
User482635)
=OR(ID2.SG1>(H-3*TICKSIZE),ID2.SG1<(L+3*TICKSIZE))
Date Time Of Last Edit: 2022-04-27 14:51:22
imageSierraChart_64_Xs3YGbFjxu.png / V - Attached On 2022-04-27 14:50:47 UTC - Size: 69.48 KB - 159 views
imageSierraChart_64_J5J9rWLGGa.png / V - Attached On 2022-04-27 14:50:57 UTC - Size: 57.36 KB - 154 views
