Date/Time: Wed, 26 Feb 2025 19:06:39 +0000
Volume Profile of Composite disappears
View Count: 504
[2021-05-29 09:19:21]
maxm1987 - Posts: 119
Dear Support Team
I have some difficulty with the display of the composite VP. I provided you the respective chartbook plus two pictures. The first one does display the MC Profile and this happens when is click and drag the main price chart all the way to the right. If I click and drag it just slightly to the left the MV Profile disappears (second picture)
Please advise
attachmentChartbook2.Cht - Attached On 2021-05-29 09:16:14 UTC - Size: 11.88 KB - 322 views
imageMC1.JPG / V - Attached On 2021-05-29 09:16:21 UTC - Size: 292.79 KB - 181 views
imageMC2.JPG / V - Attached On 2021-05-29 09:16:28 UTC - Size: 249.42 KB - 254 views
[2021-05-31 14:06:31]
John - SC Support - Posts: 38212
We are not able to reproduce what you are seeing with the Chartbook you provided. It is working just fine for us.
The one thing we want you to try is to update to the latest release and then see if you have the same problem. To update, follow these instructions:
