Date/Time: Tue, 04 Nov 2025 18:18:52 +0000
Renko in Ticks
View Count: 2970
| [2013-04-22 11:50:46] |
| abrown8703 - Posts: 64 |
SC, or anyone. Is there a study when applied to a "Renko in Ticks" chart, will alert me on the closing of a up/down bar? Or tell me how many ticks before candle closure(I've tried the Count Down Timer study, which did not work). To your continued success! |
| [2013-04-22 16:23:21] |
The Countdown Timer study does have an Alert on New Bar input which can be set to Yes which should give you an alert.
| [2013-04-22 16:35:58] |
| abrown8703_ - Posts: 4 |
The Countdown Timer does work when using time, volume, tick etc. It does not work with "Renko in ticks" charts. For these, it displays "0." Please advise.
| [2013-04-22 16:53:01] |
Yes, it will display zero, but it should give an alert when there is a new bar.
