Date/Time: Mon, 25 Nov 2024 20:25:21 +0000
rollover
View Count: 1001
[2014-03-13 07:36:41] |
User78347 - Posts: 17 |
when I want to do a rollover to the next symbol the other buttons which allows to loads data more then 15 days are locked. how can I unlocked these buttons? or how can I do more then 15 days rollover? please see the attached file |
2014-03-13_rollover.png / V - Attached On 2014-03-13 07:35:09 UTC - Size: 16.88 KB - 355 views Attachment Deleted. |
[2014-03-13 08:59:21] |
You are running an older version of Sierra Chart. Update Sierra Chart by selecting Help >> Download Current Version and use the new Continuous Futures Contract feature: https://www.sierrachart.com/index.php?l=doc/doc_ContinuousFuturesContractCharts.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-03-13 09:31:29] |
Thank you for your answer. i updated the sierra version but now the rollover slide doesn't show any posabilities to how meny days backward to include the data. How can I choose how meny days?
[2014-03-13 09:33:41] |
There is no need for that outdated method anymore. Use the new Continuous Futures Contract feature: https://www.sierrachart.com/index.php?l=doc/doc_ContinuousFuturesContractCharts.html After setting the feature you just need to set the Days to Load in Chart >> Chart Settings to what you require. The step-by-step instructions on that page guides you through this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-03-13 09:37:49
