Date/Time: Wed, 26 Feb 2025 17:49:25 +0000
Price change on charts not in sync.
View Count: 449
[2021-05-28 12:02:39]
58LesPaul - Posts: 429
I'm using delayed data and have 3 charts in my chartbook of ESM21, hourly, 15 minute and 5 minute. I notice price updating at the same time with the hourly and 15 minute but the 5 minute is not in sync with the other two charts. Seems the 5 minute will lag behind for up to 10 seconds but most times it is a second or two, but then it seems to be ahead of the other two charts with the next move.
[2021-05-28 13:04:16]
5 minute on right. 15 minute middle and hourly on left.
Date Time Of Last Edit: 2021-05-28 13:54:57
Private File
[2021-05-28 14:30:39]
John - SC Support - Posts: 38204
Check the Chart Update Interval for the charts and make sure they are all set to use the Global setting for this (they should all be 0). refer to the information here:
Chart Settings: Chart Update Interval in Milliseconds (Chart >> Chart Settings >> Display >> Chart Update Interval menu)
If these are the same, then we would wonder if there are additional studies on the 5 minute chart that are not on the others that may be taking more time to update.
