Date/Time: Wed, 26 Feb 2025 17:53:27 +0000
MBO Data
View Count: 590
[2021-05-27 19:32:27] |
Ben A - Posts: 123 |
Hi, I do not have any MBO data today, can you advise if there is an issue? Thanks |
[2021-05-27 20:57:29] |
Refer to: Notice: Denali Data Feed - Market By Order Changes (Full delivery down to quantity 2) | Post: 267119 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-05-28 13:19:24] |
Thanks, Will we be able to filter the MBO again at some point in near future? Having min lots as 4 makes it unusable for my purposes. Thanks! |
[2021-05-28 14:33:20] |
John - SC Support - Posts: 38206 |
You can still set the Minimum Value to be displayed to something greater than 4. This has not changed. The instructions are here: Market By Order Data: Adjusting Minimum Quantity to Display for Market by Order Data For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-05-28 15:30:05] |
Ah great, I must have misinterpreted the guidance. Thanks!
