Date/Time: Wed, 26 Feb 2025 18:03:49 +0000
NO MBO on Eurex today
View Count: 489
[2021-05-27 06:56:15] |
User657945 - Posts: 226 |
Can you please check till yesterday evening MBO was ok this morning no MBO. THX made a check disconnect and reconnect right now no change no MBO. Date Time Of Last Edit: 2021-05-27 06:57:45
[2021-05-27 07:11:38] |
I found your notice but I do not have the option use a separte conenction on my version. You will need to set Global Settings >> Sierra Chart Server Settings >> Use Separate Connection for Market by Order Data to Yes. |
[2021-05-27 07:18:09] |
You need to update to current version. Instructions: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-05-27 07:21:55] |
ok thx it works now
Date Time Of Last Edit: 2021-05-27 07:26:10
