Date/Time: Mon, 25 Nov 2024 08:51:56 +0000
Call External Program on Alert Not Working
View Count: 887
[2021-05-27 02:33:15]
Metzenovich - Posts: 10
I want to run an external PHP program when an alert gets triggered.
I've tried entering these into the field:
c:\php\php.exe c:\folder\script.php
c:\php\php.exe -f c:\folder\script.php
c:\\php\\php.exe c:\\folder\\script.php
c:/php/php.exe c:/folder/script.php
All of these result in:
"Error creating process c:\php\php.exe c:\folder\script.php. Windows error code 2: The system cannot find the file specified.
If I run these from the command prompt it works fine:
What is the right way to format this?
Thanks!
[2021-06-02 20:10:38]
I wasn't able to find a solution to this, so I created a C program that does what I need, so I just run the .exe, which needs no arguments. It's faster as well.
[2022-01-21 09:23:50]
Sargon Petros - Posts: 57
Hey there,
How did you get the calling of the external .exe to work? For some reason regardless of whether I use the full path or not, the program never gets called despite the alert condition being met.
[2022-01-21 17:00:04]
Check the Window >> Message Log in Sierra Chart at the time you expect the program to be run. You will see a line indicating the program being run and there will be an error message shown.
Date Time Of Last Edit: 2022-01-21 17:23:19
[2022-02-03 16:20:42]
Sierra_Chart Engineering - Posts: 17172
We have implemented a solution to post #3. Update to the latest prerelease:
[2024-03-13 04:25:16]
user_xyz - Posts: 416
I'm running the latest version of SC and trying to debug running program on alert.
I am not seeing any lines regarding the alert in Message Log. The alert fires, alert manager window shows the alert, I hear the audio message and see the cme.exe window flash open but nothing is showing up in Message Log.
Did something change?
[2024-03-13 04:37:48]
We checked and there is no Message Log message for this. We will add this to the next release. We will also implement support to show the error message.
[2024-03-15 14:55:32]
I downloaded the latest release and don't see anything in the logs yet has it been added?
Date Time Of Last Edit: 2024-03-16 08:29:54
