Date/Time: Wed, 26 Feb 2025 17:44:43 +0000
Volume Display/Format for large numbers
View Count: 1178
[2021-05-26 18:10:24]
User761716 - Posts: 6
Hello SC,
Let's choose the volume indicator.
Is it possible to change the way large numbers are displayed ? For example, I'd like to see something like 700 000 000, 700.000.000, 70M instead of 7000000000.
bests
imageSans titre.png / V - Attached On 2021-05-26 18:09:34 UTC - Size: 14.69 KB - 224 views
[2021-05-26 18:18:57]
John - SC Support - Posts: 38201
Set the Value Format for the study you are displaying to Large Integer with Suffix. Then anything greater than 9,999 will get shortened and have a size suffix appended to it. Refer to the information here:
Chart Studies: Settings and Inputs Tab >> Value Format
