Date/Time: Wed, 26 Feb 2025 16:15:24 +0000
Trading DOM Rows
View Count: 766
[2021-05-26 15:35:05]
Mustang77 - Posts: 122
Hello
How can i make the DOM rows height bigger? and make the numbers bigger? i find them too small to read...
[2021-05-26 15:42:25]
John - SC Support - Posts: 38179
To make the DOM rows bigger, you just need to expand the scale. Refer to the following:
Chart Scale and Scale Adjusting: Interactive Scale Range - Expand/Compress Scale
To change the numbers bigger, you need two different font settings. The Chart Text will change the font of the Price Ladder and the DOM Quantities will change the font of the Market Depth data. Refer to the following and the one after it:
Graphics Settings: Chart Text - (current font name)
