Date/Time: Wed, 26 Feb 2025 15:56:45 +0000
data to a csv file
View Count: 417
[2021-05-26 15:31:15]
MichaelG - Posts: 34
is there a way i can have feed a csv file with live data?
[2021-05-26 15:39:21]
John - SC Support - Posts: 38179
It depends on what data you are looking for, but refer to the following study:
Write Bar and Study Data To File
Any other data is not directly available in terms of live output. You would need to write a customs study to get whatever other data you are looking for. Refer to the following to get started:
Advanced Custom Study Interface and Language (ACSIL)
