Date/Time: Wed, 26 Feb 2025 17:49:26 +0000
Keyboard shortcut configuration: Scale and extending rectangle
View Count: 732
[2021-05-26 11:55:17]
User143517 - Posts: 68
Hi there,
Two questions regarding keyboard shortcuts configuration:
1) I have been trying to set a keyboard shortcut that just opens the scale settings window(I have been using Right click + Scale Settings). However, I could not find an option to do that on the Customize Keyboard Shortcuts menu. Is there an option for that?
2) Similarly, I want to set a keyboard shortcut for opening an extending rectangle chart drawing properties window(I have been using Right click + Chart Drawing Properties) and could not find it either.
Thanks in advance.
[2021-05-26 14:24:27]
John - SC Support - Posts: 38204
1) There is not an option for a keyboard shortcut for the Scales window.
2) There is also not a way to open the Drawing Properties for a drawing. The tough thing about this, is how to select the drawing for the Properties window.
[2021-05-27 10:34:27]
Thanks for your prior response.
Regarding your answer to my 1st question, I was thinking, Is there a way to set a shortcut to directly input/change the range value for the Constant Range/Manual mode then?
Date Time Of Last Edit: 2021-05-27 10:34:53
[2021-05-27 13:43:11]
Sorry, this is not available either.
