Date/Time: Mon, 25 Nov 2024 20:53:49 +0000
Exclamation Mark
View Count: 1249
[2014-03-12 19:35:34] |
beppinino - Posts: 18 |
Hello, I was looking inside the program documentation but did not. Please, what is meant by the exclamation mark placed near the symbol characters. Date Time Of Last Edit: 2014-03-12 19:36:42
12- 3- 2014 20-26-00.jpg / V - Attached On 2014-03-12 19:32:24 UTC - Size: 222.32 KB - 376 views |
[2014-03-12 22:04:48] |
The ! means that an Alert Condition Formula you set up in Chart >> Chart Settings is TRUE.
[2014-03-12 22:11:56] |
OK, Thank´s very, and also for patience. Now it´s clear.
Date Time Of Last Edit: 2014-03-12 22:16:23
