Date/Time: Wed, 26 Feb 2025 17:42:58 +0000
LOCKING UP
View Count: 523
[2021-05-26 04:18:39]
User398539 - Posts: 9
THIS PROGRAM KEEPS LOCKING UP ,, VERSION 2171 64 BIT (33267M)
WINDOWS 8
[2021-05-26 13:58:30]
John - SC Support - Posts: 38201
We need more information on exactly what is happening in terms of "locking up". In particular, is the data stopping, but are you able to interact with the User Interface? Do you have a lot of drawings on the screen, or using a lot of transparent items? Does it just interact slowly, but does "catch up" to what you want to do? Is there something specific you are doing when it "locks up"?
[2021-05-26 14:11:31]
Sierra_Chart Engineering - Posts: 18569
We also need you to update to the current version of Sierra Chart following these instructions:
You cannot continue to run an older version.
[2021-05-26 19:47:49]
So what happens is it.. the mouse sits and spins only on the sierra platform.. I can still access my interactive brokers
platform with ease... mouse over to SIERRA-- AND THE MOUSE IS SPINNING... A RESTART OF SIERRA IS THE ONLY FIX FOR NOW
THX
[2021-05-26 19:55:58]
Ok, that gives us some information. Exactly what was the last thing you did prior to it "locking up" as it did? Is it a reproducible thing, or is it just happening at random?
[2021-05-27 01:53:39]
First thing we want to do is go through the items in this help topic:
High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often
See if there is a study with a very long calculation time.
Also run Sierra Chart in Safe Mode:
Sierra Chart - Software Login Instructions: Using Safe Mode
[2021-05-27 02:19:13]
JUST RANDOM.. STRANGE
[2021-05-27 03:03:43]
Update to the current version:
Date Time Of Last Edit: 2021-05-27 03:04:00
